U0155
Old 11-28-2018, 01:12 PM
aneranch's Avatar
Default U0155
2007 Honda Civic just decided NOT to show travelling speed, hand brake light is on, engine check on ... ABS on ...
It runs normally , starts normally - but the dashboard is going nuts.
Plugged in ODB scanner and read code U0155 - communication failure with "instrument module" .
Proceeded with "recommended remedy " disconnect battery for 5 minutes.
Same stuff - but the ODB scanner no longer works !
No ODB "experts " on web say - bad ground on "IPM" instrument panel module (?)
But they do not say WHERE is this module?
Can somebody give me a hit , from actual experience preferred? I can "guees" by myself :
1. where is this module
2. where do I find PROBABLE missing / intermittent ground connection for it ?
This is most recent electrical problem with 100000 miles plus Honda.
The gas gauge goes nuts intermittently missing last two or three "empty" segments .
Somtimes it shows exact opposite tank "state" - the two or three segments on "full" scale are ON , while the rest of it - down to "empty:" - is dark! (No recall ?)
After dealer changed the recalled passenger (?) side air bag - the radio intermittently works ONLY on RIGHT FRONT door - no place else !
My educated guess - I am missing ground - the question - WHERE?
Live in Huston - no salt on roads here !
Please - serious replies only - " no check the brake fluid etc "..
Appreciate any help leading to resolution BY FIXI'N it myself.
Cheers
Causality
10-06-2017 04:48 AM
GreenMunster
09-15-2014 11:28 AM
Gabe11
18
03-08-2012 01:55 PM
supermannnnn
02-21-2008 04:31 PM
mcx76
01-15-2007 05:50 PM
Quick Reply: U0155
