90 EF f22a1 sohc swap??
Old May 12, 2011 | 10:35 AM
armando.408's Avatar
Question 90 EF f22a1 sohc swap??
ok i got a 90 ef h/b 5 speed it has a weeeeaaaak! d15 stock! i have a sohc f22 pumped up a bit that i want to swap in it do i need to change or reconfigure anything?
Old May 12, 2011 | 10:36 AM
Default the f22 came out of a 96 prelude..
cant forget that 96 prelude 2door
Old May 12, 2011 | 05:30 PM
Shandles's Avatar
yes, you'll need a ton of shiz. You'll need a new ECU, wiring harness, custom mounts, custom axles and whatever parts the motor doesn't have. Like a header. Whats your exhaust setup like? you'll probably need that either replaced or welded up to your new header.
And if Im not mistaken, to get an H-series into an EF civic you also need a JDM SIR hood. not sure if you'll have the same problem with the SOHC F22...
Old May 14, 2011 | 07:31 PM
what kind of custom axles and custom mounts? and can i use the original mounts for it? and where can i get the hood at? and the exhaust is stock but not worried about that going to weld that up.
Old May 16, 2011 | 08:56 AM
Shandles's Avatar
if someone does make mounts for it, I'd check Hasport. Or even ebay, but generally... you get what you pay for. Ebay mounts may break or rust then break. If hasport makes mounts for it, they'll make axles for it too. Its not cheap.
besides hasport also check out Avid Motor mounts. cheaper, but still good quality.
Old May 16, 2011 | 07:08 PM
Hailchristian's Avatar
Could also do a F2B swap. Basically take you F series engine, get a b series transmission adapter and bolt up a B series transmission. It is a much more common swap from what I have read then just dropping in a F series tranny and engine.
As for the hood, most people just add some washers and space the hood up. I don't think the JDM front end would give you really that much clearance. I have one on my car.
Check out this for more information:
H2B / F2B FAQ - Honda-Tech
Old May 17, 2011 | 12:25 AM
zerojett's Avatar
EF 88-91 Civic/Crx H22A Motor Mount Kit complete kit includes:
(1) Driver side motor mount
(1) Rear engine mount
(1) Rear chassis mount
(1) Weld in or bolt in passenger side chassis mount, prefer weld in.
(1) Passenger side motor mount
(1) Alternator upper bracket and bolts
(1) Tensioner bracket for upper (your choice of bracket for either H series or D series alternator). Pictured below.
(1) Clutch cable/hydro conversion lever system (pictued below)
(1) Passenger side chassis new hole template only for 90-93 DA H22A motor mount kit
$499 shipped
EF H22A Key Parts List:
Swaping out Front Hub/Spindle/Knuckle and Caliper and Rotor to a 90+ Acura Integra is a must. Just like any B series swap. Any Honda/Acura junkyard will have them for a decent price.
90-01 Acura Integra Front Hub/Spindle/Knuckle/Caliper/Rotor
Axle Combo:
88-89 Acura Integra driver side axle off shelf parts store.
90-93 Honda Accord Ex or Lx model midshaft
88-89 Acura Integra passenger side axle that has been cut down 1/2" on the shaft and has an Accord 90+ Inner joint put on it. Raxles.com sells this 1 custom axle. Ask for Marty.
Cable Shifter Assembly:
90-93 Honda Accord cable shifter assembly and cables will work with the swap or 92+ Prelude. Make sure you keep all the washers and clips organized.
Wiring Options:
Obd0-Obd1 conversion is a must. 2 ways to go about it pick up a RYWIRE (Rywire.com) Obd0-Obd1 jumper harness and doing the wiring your self, mostly extending wires to reach on the H22 engine and maybe a few sensor swaps. Roughly about a day's work. Easier to do the wiring adjustments when engines out of car. Or last option is the easiest and which I prefer saves wiring headaches and mistakes. Purchasing a custom RYWIRE (Rywire.com) Obd0-Obd1 EF H22A plug and play harness already made. Took me 10 min to put on . Just send them your factory EF engine harness and the H22A engine harness and about $400 and they will make your custom harness. Looks real nice and simple I use them for all our EF H22 swaps. I can't say enough good about them.
Explicit Speed Performance
MarcB
EG Swaps
Oct 7, 2015 06:51 PM
broke77f100
Jan 2, 2008 05:29 PM
kbeers
Jun 23, 2006 11:56 PM
EMPOY55
Jun 14, 2006 08:58 PM
Justpassing through
Sep 1, 2005 06:39 PM
