91 civic alternator pulley
Old Nov 27, 2009 | 11:40 AM
lostforawhile's Avatar
Default 91 civic alternator pulley
looking for a 91 civic alternator pulley, to do the alternator move on my 86 accord, the four rib pulley, i haven't been having any luck at all finding one. it happens to match the original ac pulley groove for the accord, and the alternator is going where the ac was, thanks guys!!
Old Nov 28, 2009 | 04:08 PM
You can put a 3-rib belt on, even though the crank pulley has 4 grooves. The belt will run OK and stay in the 3 grooves you place it on.
Old Dec 28, 2009 | 08:47 PM
well the factory alternator has five grooves, and the civic pulley has four,matches the AC belt and the four grooves in the crankshaft pulley,
Old Dec 29, 2009 | 12:39 AM
Well then I would imagine that you could put the 4-rib belt on even though the alternator has 5 grooves.
Old Dec 29, 2009 | 10:27 AM
I just don't like doing things half *** is all, there's a lot of work in this car already, i would rather put the correct pulley on this accord alternator.
Old Dec 29, 2009 | 10:29 AM
It's really not that "half ***." I have a Mazda that came from the factory with the belt narrower than the pulley like that.
Old May 23, 2010 | 01:48 PM
I looked at doing that, but it looks like the belt could skip a groove and start running misaligned, i found out a 98 pulley will work too, the one for the mitsu alternator, 15mm bore pulley, so i'm still looking for one.
Old May 30, 2010 | 06:39 PM
bumping this back up, i can use a 98 one, the one with the 15mm bore, I need it to get my alternator finished moving
Old Aug 14, 2010 | 08:41 AM
bump, how difficult can it be to find an alternator?
myhondacivicforumacct
Jul 26, 2011 09:28 PM
Karrde
12
Jan 24, 2009 05:09 AM
grunge
Sep 24, 2006 09:00 PM
ATF
14
May 12, 2005 11:44 PM
ATF
May 8, 2005 01:47 PM
