HondaCivicForum.com
-   -   91 civic hydraulic clutch question? (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/91-civic-hydraulic-clutch-question-79754/)
doctorz Dec 3, 2009 05:35 PM
Can I take hydraulic clutch petels, master cylinder, and slave cylinder out of a 94 integra and makee it work in my 91 civic hatch. If not why? I'm willing to do some fab work. Has it already been done. I have the means to do it just want someones input.
94civichatchback Dec 3, 2009 08:15 PM
it wont mount up to the firewall, you will need to make a custom plate. but yes it has been done, just a big pain
mk378 Dec 4, 2009 04:30 AM
Really the only reason to do this is because you've swapped the transmission to one that's set up for hydraulic clutch. With the stock transmission just use the cable. New clutch cables are not very expensive if you need one.
98gsr-turbo Dec 4, 2009 09:52 AM
id do the hydro swap for a number of reasons. 1 a hydro trans is more durable for power mods 2 easier to drive with a more aggressive clutch 3 got more choices for different gear ratios that would best suit your mods and 4 a b swap is way easier to do in an ef when its for a hydro car.
doctorz Dec 4, 2009 02:35 PM
OK cool. I have no problem building a plate or this http://www.suja1motoring.com/product...px?productId=1. I would like to do this kit but I can barely justify spending $150 on some thing I can probable make.
