HondaCivicForum.com
-   -   92 Civic Check Engine Light (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/92-civic-check-engine-light-72142/)
zmd73 Dec 13, 2008 05:12 PM
Hello There
I have a 92 Civic DX with 200K the check engine light just came on. I went to my local Autozone to help me read what it could be. They could not find the connector to read the code. Does anyone know where is the plug?
Thanks
trustdestruction Dec 13, 2008 05:58 PM
It's on the passenger side, under the glove box and against the side wall.
You can actually check it yourself very easily. Scroll through this link until you find the section that says "CK ENGINE LIGHTS-pdiggitydogg" in red text.
http://www.honda-tech.com/showthread.php?t=878010
RonJ Dec 13, 2008 07:08 PM
Yeah, your 92 Civic is OBDI. AutoZone generally can only pull codes from OBDII cars. As Trust says, go to the CEL link, which shows you how to pull OBDI codes using the handy-dandy jumper wire method. Post retrieved codes for feedback.
