93 civic dead cylinder
Old Mar 12, 2012 | 04:37 AM
cropduster001's Avatar
Default 93 civic dead cylinder
I have a 93 civic 1.6 with a dead cylinder. I drove it in the morning and when I started it in the afternoon it had a dead cylinder. I replaced the cap, rotor, wires and fuel injectors. Where do I go from here?
Old Mar 12, 2012 | 05:12 AM
Test the compression.
Old Mar 13, 2012 | 09:14 AM
30lbs with engine started, injector disconnected.
Old Mar 13, 2012 | 11:42 AM
Test the compression with the starter only, don't start it. Take out all the plugs and disconnect the low voltage wires to the distributor to prevent firing the ignition into an open circuit.
It sounds like that cylinder is about zero. The next check is to take the valve cover off and make sure all the rocker arms go slack when they should (valves closed with cylinder at TDC). If it's not the valve adjustment you have an internal mechanical problem and the head will need to come off to check further.
Old Mar 23, 2012 | 05:55 AM
Leak down test coming out of exhaust.
Old Mar 23, 2012 | 06:18 AM
switch263's Avatar
30 PSI is awful low. Like mk378 said, I'd next pull the valve cover off and make sure all the rocker arms go slack. (valves closed with cylinder at TDC). If that's not it, you'll likely end up pulling the head to look for other mechanical problems.
The leakdown results you're stating seem to point to a possible valve issue though, so hopefully it's an easy fix (compared to pulling the head and whatnot, at least....)
Old Mar 23, 2012 | 06:23 AM
Strange how it was fine one moment and when I started it later on the problem was there with no previous warning signs.
Old Mar 23, 2012 | 06:29 AM
switch263's Avatar
It could be a stuck valve (which can easily happen 'suddenly' like that, I've seen it a few times on bikes). Or it could just be horrid timing and something worse. :/ Unfortunately until you tear into it, I don't have any other ideas, myself at least.
Peg_Leg
XBox/XBox 360
May 7, 2010 06:42 PM
nasoj007
30
Dec 19, 2008 02:14 PM
AnimalWild
Jun 27, 2008 11:46 AM
91Civic4lyfe
May 25, 2007 03:31 AM
