93 Civic Fuel injector issue?
I have a '93 Civic DX D15B7
It has been a very reliable car but last Tuesday it failed to start after sitting for 3 days. Here is what I have done so far: Car turns over, all valves are moving I have spark but no fuel at the cylinders I have fuel at the fuel rail. I swapped the ECU (junkyard, not a known good one) with no luck The car acts the exact same with either ECU or no ECU at all installed. No CEL or code to go off of Tried disconnecting the TW switch and it finally gave a CEL. Basically the Fuel injectors are not operating, it had no symptoms leading up to this to this. Any ideas would be appreciated, Thanks Mark |
Try swapping out the main relay..
Well never mind, wouldn't you know it I monkey with it for 2 days to no avail only to figure it out 1 hour after posting here. Turns out it was the TW switch, but I needed a jump start because the battery was low by the time I tried disconnecting the switch.
Originally Posted by Mark_30ish
(Post 788129)
