93 civic lx turns over but wont start
Old Jan 2, 2012 | 05:32 PM
HondaLady's Avatar
Unhappy 93 civic lx turns over but wont start
OK I have a 93 civic and had head gasket replaced and the timing belt and distr replaced.. Now it wants to start but wont plugs have spark when i try.. What do I do to fix this problem? could someone give accurate directions on what to do or simply give me a place to look online like an online manual?
Old Jan 2, 2012 | 09:12 PM
Let's start again. Was it ever able to start after the work was done? What led to replacing the head gasket? Driving overheated until it will go no more almost always means the whole engine is toast.
Old Jan 3, 2012 | 09:36 AM
HondaLady's Avatar
The head gasket went out.. It started running hot so stopped driving it.. never drove it all the way hot and kept going. and no it didn't wanna start back after replacing the 2.. It started before i had the head gasket replaced and tried to start when i realized the timing belt needed replaced.
Old Jan 3, 2012 | 11:12 AM
So like in the other thread, you should check the firing order, mechanical timing, and valve adjustment. A compression test would confirm that the basic mechanicals inside the engine are OK enough for it to start.
RobTimmerman
Oct 16, 2012 03:16 PM
MCELROY
Apr 9, 2012 03:22 PM
johnpg1957
Mar 14, 2012 04:32 PM
gti113
Jan 16, 2009 11:02 AM
MuffinMan21
Jul 27, 2008 09:08 PM
