93 honda civic starting problems
i have a 93 honda civic and every now and then the car wont start.. i replaced the gas pump cause the car has 217,000 on it but it still doese it.. it happens alot when the ac unit is on but also happens with the air off.. takes 5 - 10 trys to get it to start up it has good spark plugs in it and good wires any 1 know what might be going on?
RE: 93 honda civic starting problems
Check your main relay.
Does it happen when the engine is warm or cold? Like will the car not start you have driven it, turned it off, and try to start it?
ORIGINAL: AgentofDarkness Does it happen when the engine is warm or cold? Like will the car not start you have driven it, turned it off, and try to start it? |
i have a 92 civic lx. I had a similiar problem just mine sat for a year. i couldnt figure it out for the life of me. i put new plugs and wires a new battery checked all the fuses and changed oil and tranny fluid. checked all the vacuum lines and a new fuel filter and everything i went all out trying to find the problem.
one day i picked me up a solder iron and some solder came home pulled the main relay and it looked fine. but i figured since it was already out i went ahead and resoldered every connection. since then i havent had a problem. mine through a CEL everytime i was having problems starting it. even while cranking. after a few minutes it would go off and i would hear a click in the area of the fuse box and the car would start fine. untill i fixed the main relay. it gave it a few more horses back to. |
Sounds like the main relay to me as well. I decided to buy a new one ($50) instead of re-soldering. Haven't had a starting problem since.
thanks for you guys help looks like she'll have to buy a new main relay or get 1 from the junk yard they only want 5 bucks for a relay.
Mine had similar problem. Sometimes did not start hot after it sat for a few minutes. I did not have it any more after I replaced the fuel filter.
