94 accord engine swap
i had a h22 non vtec and now i have a h22 vtec do i need a new wiring harness and i know i need a vtec computer but not sure and about wiring harness ? would the old harness plug up no problem ?
Civic forum - Accord swap. :D
You need to wire in Vtec. Contact Rywire.com, they can help you get what you need. The non-vtec harness should plug up with the exception of vtec of course. |
Ok thank you, I have never done a wire swap before , how long would it take to put the new wiring harness on
Adding vtec wiring shouldn't take long if you want to use the current harness you have.
Installing a complete new harness with the motor out of the car is easy and wouldn't take more than 30 min. In the car, you are looking at about 2-3 hours tops. I pulled my complete civic harness (chopped and routed by a shop fill with idiots) within 1.5 hours. The new harness was installed in about 2.5 hours, but I took my time with everything. |
