HondaCivicForum.com
-   -   94 civic dx temperature needle passes the middle (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/94-civic-dx-temperature-needle-passes-middle-89604/)
carlosncali Jul 6, 2011 06:34 AM
when i drive it for like 25 minuets its on the normal temperature right under the middle, then after that it starts going up a bit passing the middle and something going up as high as 3/4 the way up.
i changed the sensor and thermostat.
the thermostat is at 190 temperature
is that normal to happened on a thermostat with that temperature?
when that happeneds im afraid it might over heat and stall and get stranded
need help...thanx
