95 Civic engin question
I just bought a 95 Civic 4dr LX with 250,000 miles. It is leaking oil pretty bad, so my question is. Is it worth trying to get the leak fixed( not sure yet were it is leaking from) or should I replace the motor? How many hours would it take an experienced mechanic to swap in a different motor?
Are you also losing transmission fluid? If not, then the rear seal is leaking. If the engine runs fine otherwise, I would seriously consider just replacing the seal rather than the whole engine. Just my opinion.
So I finally got around to having it looked at and it is the rear main. Is it worth trying to fix if the car has 250K miles on it. He said it would be around $700-900 to fix it and put a new cluth in while the tranny is out. How much could I buy a used engine for? 95 1.6l.
How bad does it leak? You may be money ahead to just keep putting oil in until it needs a new clutch, then have the seal done at the same time. That price also seems kind of high for a routine clutch/seal job.
