95 dx manual running rough after 2nd start
Old Mar 23, 2009 | 06:24 AM
country's Avatar
Default 95 dx manual running rough after 2nd start
I have a 95 dx manual that is running great, except that when I go to restart it after I've stopped for food/gas/anything that only takes a couple of minutes.
The problem I've noticed is that it starts and runs really rough and seems like it wants to die. I can power through it and once I get to about 20-25 mph it starts to run normally again. I just had the thermostat replaced because it was overheating. While that was being done my mechanic decided to clean the "throttle body" (that little valve that regulates the air flow).
I don't think the the rough starts were caused by him doing that. But wtf do I know.
So cliffs: no problem starting cold, once warmed up and I turn the car off the engine runs VERY rough.
Old Mar 25, 2009 | 01:03 PM
country's Avatar
anyone?
Old Mar 25, 2009 | 01:36 PM
Is the CEL ON?
You might want to clean the Idle Control Valve (IACV) attached to the throttle body (see link in my signature).
Old Mar 26, 2009 | 05:29 AM
country's Avatar
The CEL is not on.
I will check the IACV, as my mechanic did clean the throttle body valve, and he may have dislodged/clogged something there.
Old Mar 26, 2009 | 05:34 AM
country's Avatar
I'll also check the FITV since I WAS having overheating issues. Could the overheating damage the FITV or the IACV?
Old Mar 26, 2009 | 07:12 AM
Overheating can damage many things in an engine.
I don't think the FITV is the problem as your running issue occurs only when the engine is warm/hot. The IACV is a more likely possibility.
Also inspect the spark plugs, cap, and rotor and measure the resistance of the plug wires.
Old Mar 30, 2009 | 05:34 AM
country's Avatar
Ok, so I took it to my mechanic and he looked at and cleaned the IACV. The problem did not go away. He is "thinking" that it could be a small leak in the head gasket. Which, with the cost of the radiator and labor will bring the total for this trip up to around $1000 and possibly above.
I am thinking its not worth it. Any thoughts.
Old Jun 1, 2009 | 07:01 AM
country's Avatar
Well as it turns out the head is definitely leaking. So I pulled the head off and am taking it to a mechanic to find out how much the head is warped. I have all of the new gaskets already, high temp thread locker, and some kind of silicone lube. I am going to be buying new head bolts and the copper stuff.
zrock
Sep 13, 2010 09:33 PM
Stumasters
Jan 20, 2008 12:58 PM
Jeremy102579
Dec 11, 2007 10:07 AM
mysi
Aug 10, 2007 06:51 PM
kjreinha
Feb 4, 2005 01:58 PM
