| ConfusedGuy |
Feb 7, 2020 12:33 PM |
97 Honda Cr-V no spark
Okay I know it isn't a civic but the motor and electrical is nearly identical. I am looking into a problem a friend is having. Without diagnosing anything he just started throwing parts at it. The spark plugs, plug wires, coil, and ICM are all new. Today I tested the ignition switch. All checks out good. Then I checked the main relay. It also function as it should. I am currently charging the dead battery so I can do voltage tests. I just want to get a jump on what I will be looking for when I have power. Which wire going to the Distributor is 12v supplied by the ECM? Is there a wire to test pulse at the Distributor? Does anyone have a pin out list for the ECM? Any help is greatly appreciated!
