98 civic everything shuts down while driving down the road
i have a honda 98 civic lx, and recently it has developed a troublesome problem. I will be driving down the road, and suddenly the engine turns itself off, along with no turn signals, no radio, everything shuts off. when i return the key in the ignition, everything is back on and working fine. It happened about 4 months ago, and then maybe 3 or 4 other times during that 4 months. However, this past week or two, it has become more frequent, with only one new noticable symptom. The radio started acting strange turning itself on and off randomly. The second time the radio did this, the car shut down, the first time the radio acted up, nothing else occured. Any ideas? It doesnt seem to matter if the car is cold or hot, it has mostly only happened in town, but a few days ago, it happened on the freeway, and that freaked me out. I am a new member of your forum, and any help you can give me is greatly appreciated. Thanks!
When it shuts down don't touch the key before checking the headlights, dome light, horn, etc-- stuff that does not depend on the key being on.
If everything electric is dead, it's probably a bad connection at the battery or in the underhood fuse box. If only the key operated stuff it's probably the ignition switch (the main switch that the key turns). There was a recall on the switches for doing what you describe.
so my car finally shut down today while driving down the road. I checked the horn before touching the key and yes the horn still worked, even though the motor had shut off.
So does this mean that it is probably the ignition switch? If so, how do i go about getting that repaired?
Thanks again for your help
atmg68
Sep 7, 2021 09:30 PM
stanlam
Feb 23, 2011 02:04 PM
NickF829
Sep 25, 2007 12:59 PM
EVL TTWN
Apr 12, 2006 10:20 AM
