98 civic stalling out
Old Jun 9, 2012 | 02:04 PM
torok's Avatar
Default 98 civic stalling out
hey i bought a civic with 180k miles on it for $400, right now the problem i am having with it is it will start up but will run crappy it will almost stall out and then the rpms will bounce up and it will continue to do that over and over and when im driving it will lag when i give it gas and then it will surge
after awhile of running the car will drive fine no real problems that is until i turn the car off and try to turn it back on it will start over.
just this last time driving the car it was running fine and then i shut the car off and it didn't start up it started but immediately sputtered out and every time i try to restart the car it won't start. if i give it time it will start but do the same thing, some times i can get it to start and and drive it like i said the in first paragraph
fuel filters are changed already, im trying to put as little into this car as possible
Old Jun 9, 2012 | 02:06 PM
torok's Avatar
i took those earlier
Old Jun 9, 2012 | 02:18 PM
Usually a situation like this will trigger the check engine light, meaning you can check the trouble code in the ECU. Used cars often have the bulb removed though. Does the light come on for the bulb test when you turn the key on but don't start?
Old Jun 9, 2012 | 02:24 PM
torok's Avatar
yeah it lights up on the dash with the rest of the lights but it doesnt throw and check engine light
Old Jun 10, 2012 | 02:20 PM
torok's Avatar
Bump
checked the main relay and fuel pump both are good
stokerslo
Aug 12, 2012 08:05 PM
Civic Si 00
Dec 15, 2007 01:16 PM
xxeddixx
Aug 24, 2006 05:06 PM
cdansley
Apr 21, 2006 06:57 PM
91dx
Nov 13, 2004 02:27 AM
