'99 Civic LX occassionally sputters/jerks while accelerating
Old 06-23-2015, 05:04 AM
92utownxj's Avatar
Default '99 Civic LX occassionally sputters/jerks while accelerating
As the title states, my '99 Civic LX with 190,000 miles occassionally sputters/jerks while accelerating. It first started doing it a couple months ago. It was very bad. At any RPM below 2,000 when taking off/accelerating it would barely move. It would stutter and buck. Most of the time when it was over 2,000 RPM it was fine.
I replaced the fuel filter, which I had never done in 80,000 miles. I also replaced the spark plugs, which had 30-40,000 on them. The plugs are NGK. The distributor cap, rotor, and wires have 30-40,000 miles on them.
I can hear the fuel pump prime when I turn the key before starting it. When I have below half a tank of gas it will crank longer than normal to start. If I hold the key on first to prime the pump it starts right away.
After I had replaced the fuel filter and plugs it has driven perfectly for a few weeks. Then this morning after not driving it since Friday it sputtered a couple times. Also, at idle it would occasionally feel like it was missing/sputtering a bit.
The check engine light is on, and has been for months. I had the codes read and it came back as evap/emissions. I forget the exact code. It ran perfectly for months with the light on. It could be a gas cap or the evap canister or sensor. Gas cap is cheap, the other stuff, not so much, $300 or so. That's why I never messed with it.
So, is there moisture getting in somewhere? Is the fuel pump going out? Is it something related to the CEL? Or something completely different? Thanks for the help. It's my daily driver, and my wife has needed to drive my truck since her van is having issues too. Vehicles are driving me crazy.
Old 06-23-2015, 10:56 PM
itburnswhenIP's Avatar
the specific code will tell you what needs to be checked that code is very important there also could be new codes being given how would you know ??. try cleaning the intake and throttle body also check the air filter.
Old 06-29-2015, 07:23 AM
92utownxj's Avatar
Last week took off the distributor cap to have a look. There was a lot of corrosion of the contacts. For now I cleaned them up with fine sandpaper. It's been running great ever since so I'll replace the cap and rotor. The air filter looks like new.
This morning I was finally able to get the CEL codes. They came up with P1457, and they list possible causes as loose fuel cap, vapor canister saturated, failed vent solenoid, failed purge solenoid.
The light has been on for a couple months, and it's the same code that it was when it first came on. I guess a cheap and easy thing would be a new gas cap. What are common causes of that code on a Civic?
Also, after he checked the code and I started the car to leave to CEL was off. Is that normal? Did it get reset and might come back? Thought it was strange.
Old 06-29-2015, 04:20 PM
thats the one code you don't want to see because there are numerous possible causes in the EVAP system so before you start throwing money at it i would suggests you have a shop smoke test the evap for leaks in order to pinpoint the exact trouble spot.
Old 06-30-2015, 07:10 AM
92utownxj's Avatar
That's what I thought after reading several posts about it. Some of the parts, if needed, aren't cheap either. So far the CEL hasn't come back on. We'll see.
civicchica25
05-04-2011 11:09 AM
J-star
05-16-2009 06:41 AM
JohnAy
10-06-2008 06:52 AM
elysian
02-15-2006 08:09 PM
Falhawk
07-14-2005 03:12 PM
Quick Reply: '99 Civic LX occassionally sputters/jerks while accelerating
