HondaCivicForum.com
-   -   98 Heater Blower Motor (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/98-heater-blower-motor-86998/)
dwick2112 Dec 29, 2010 11:18 AM
It seems that my son's Civic's heater blower motor is making bad noises; likely will need to be replaced. A check of the service manual suggests that, since this car has A/C, the A/C evaporater needs to be removed to access the blower motor. Is this really true or is there some undocumented trick that gets around that?
Thanks in advance folks!
mk378 Dec 29, 2010 01:05 PM
That is not true. The motor can be removed without taking anything else apart. Unplug the wire, remove 3 screws around the round part, and drop it out the bottom.
cvcrcr99 Dec 29, 2010 01:07 PM
^^ exactly what MK378 said. It is very easy to access the blower motor in these vehicles. The noise you are hearing is probably a bearing gone bad. My bros 98 civic did the same thing shortly after he purchased it about a year ago. He replaced the motor for like $30 from a junk yard and everything has been fine since.
dwick2112 Dec 29, 2010 02:52 PM
Cool! Thanks much!
mundy5 Dec 31, 2010 08:07 AM
keep us posted when you do the repair.
chipfriedlinhaus Jan 26, 2011 11:48 PM
Would this be an easy fix? Since there are no tricks involve I guess all you need to have is the right tools to remove the blower.
__________________________________________________ __
mundy5 Jan 27, 2011 05:33 AM
it looks that way. I've never done it, but if what mk describes is all it takes, that's a pretty fast repair.
mk378 Jan 27, 2011 07:09 AM
I think chipfried is just a spammer-- 2 posts and a handy link to some sort of "parts store" in his signature.
mundy5 Jan 27, 2011 07:42 AM
good catch, mk.
