99 civic dx tranny
Old Oct 29, 2008 | 11:39 AM
if the replacement tranny is only 300bucks with a 30day warrente id say go for it! just be sure to change the fluid in the tranny. since its out of the car you can easily just turn it over and let almost all of it run out. same with torque converter. hopefully the replacement tranny also comes with the torque converter as well just incase theres a problem with yours.
thats one reason why i love a 5speed... if a gear goes out just skip it.LOL
but if you plan on keeping the car for along time the rebuild might not be so bad of a idea to spend the extra money!
if mine ever has a problem im gonna take it in for a complete rebuild. plus its cheaper if you drop the tranny yourself and just drop it off to them no removal or instal fees! that alone can save ya 500bucks easy!
Old Oct 29, 2008 | 11:49 AM
If you get the transmission flushed, don't get it flushed with the machine, the machine can stir around debris in the transmission and mess up the tranny prematurely.
Do repeated drain and refills to achieve similar results as a flush.
Old Oct 31, 2008 | 08:22 AM
ccwhit7's Avatar
Originally Posted by StonedCold
so its a shop kind of thing huh. Found a used tranny for $300. Got a 30 day guarantee.
Just don't know how hard to swap em out would be. Or if it would be worth it.
Dont rebuild just replace with a JDM . Way cheaper than rebuild, For 1500 you can about do a whole engine tranny swap jdm syle
Old Nov 1, 2008 | 10:03 PM
StonedCold's Avatar
I keep seeing this JDM thing- what is it? I'm a Jeep guy....
Old Nov 1, 2008 | 10:16 PM
JDM is Japanese Domestic Market
so if an engine is JDM, it came from Japan. The good thing about JDM motors is that they usually have low miles when they are sold used, and the JDM counterpart to a USDM motor is usually a bit more powerful.
Old Nov 2, 2008 | 01:37 AM
but just because it sayd JDM dont always believe it.LOL
just look at ebay and type in JDM... its thrown around so loosly it doesnt mean alot anymore IMO...
Old Nov 2, 2008 | 09:23 AM
yea i forgot to mention that
completely true though.
the way you can tell if something is actually JDM is that usually it is a used part
and it helps to know what the JDM stuff is suppose to look like prior to seeing it for sale
for examples, check out passwordJDM.com and go in the used section, that's all legit JDM
Old Nov 2, 2008 | 11:15 AM
StonedCold's Avatar
I'm going to try the several flush method. What do I do? Drain and refill I know- but do I run it? Put it thru the gears? Drive it between flushes? I don't know squat about Hondas cept for they suck when they break down! LOL
Old Nov 2, 2008 | 11:17 AM
drain and refill, then drive it. Let it cool down, and drain and refill again. Use only Honda ATF
Old Nov 2, 2008 | 11:29 AM
complete dito.
