99 civic, need help please....
Old Nov 6, 2009 | 06:33 PM
wildtouchs's Avatar
Default 99 civic, need help please....
i have a 1999 civic ex with an automatic transmission....earlier in the year, i had to replace the drive axle that goes into the side of the transmission, after that, the trans didnt seem to want to work, however, if u start the car off in low, it will go and shift (but kinda hard) to the next gears until it gets to D, then it the rpms will increase.....but the car wont increase in speed...the D4 light is flashing (where it has P, R, D4, D3 and so on)....would anyone have a guess as to what this may be? i know that the motor is not the original one, but the tranny is...could the computer be the one that goes to the other engine? how would i find this out? thanx for any help
Old Nov 6, 2009 | 09:06 PM
are you sure the cv axle is pushed in all the way into the trans?
Old Nov 7, 2009 | 05:35 AM
wildtouchs's Avatar
i believe it is, the person who put it in for me says it is, ??
Old Nov 7, 2009 | 06:49 AM
Check the fluid level. When you pull an axle out, some fluid will run out and needs to be replaced. Or like '94 said, if the axle isn't all the way in, it will leak. Use only Honda ATF, not generic ATF from a parts store. Make sure that your mechanic didn't put generic ATF into it. Do not drive the car if the transmission is acting up like it was, it will quickly cause further damage.
Old Nov 7, 2009 | 10:48 AM
wildtouchs's Avatar
the fluid level is not low, nor is it leaking anywhere, im not sure why the D4 would be flashing though.....it goes in low all the way up to drive.....
Old Nov 8, 2009 | 07:44 AM
D4 flashes because the computer has detected slippage in the transmission (there are input and output speed sensors). In this condition, the computer will only allow gears 1-3 to work; it will lock out 4.
Old Nov 10, 2009 | 05:48 PM
wildtouchs's Avatar
ok, so the tranny is shot??? sorry, i am ignorant to this.....does this mean that one of those sensors could be bad? which sensor would it most likely be if so???
Scout1
Dec 25, 2011 06:54 AM
DontHateOnEG8
20
Sep 6, 2008 06:49 AM
D16racerchick
Jan 3, 2008 05:15 PM
Honda99Civic
Apr 20, 2006 10:13 PM
CivicCrazy
Nov 29, 2004 11:50 AM
