'99 Civic stutter on acceleration
OK, here's the history of the car:
1999 Civic DX hatchback with 132k miles. 5-speed manual tranny. I'm the original owner. Had a garage replace the timing belt at 95k, then immediately replaced the plugs, wires, distributor cap/rotor myself. Just replaced the air filter last month. And here's the symptom; just started last weekend: On acceleration, and only in 1st or 2nd gears, the car will intermittently stutter or pulse as if it misfired. If this happens at all, it will happen only once or twice during accelerating in 1st, then maybe again only once or twice while revving through 2nd, and then that's it. Don't think I've ever felt the stutter in 3rd through 5th gears. Only happens on acceleration; never when holding a steady speed. Because the plugs/wires/distributor/timing belt have been serviced, my first guess is to blame the fuel filter, which I've never replaced. Do you agree? If so, is it documented anywhere on this forum as to where the fuel filter is located, and what the replacement procedure is? Thanks! Steve |
same here
I had the exact same symptoms, but new wires/plugs/rotor button fixed it. Did you replace your rotor button when you replaced the distributor cap?
Originally Posted by Ohio3Der
(Post 776250)
Originally Posted by SteveWeb
(Post 776260)
I think so, but it was a few years ago. When you say "rotor button", are you referring to the thing that spins inside of the distributor cap? If so, I'm sure I replaced that.
Suggestions on how to fix that? If you're going to say to drill it out and then tap new threads, then my next question will be how to get a drill into such a tight place. Or are there other ways of backing a cross-threaded screw out? Or, better yet, are two out of three screws enough? |
OK, fixed my problems. Here's how:
Now the car runs without stuttering, and the new bolts/nuts/washers won't break in the future in a way that will leave them stuck in the distributor. Because they're thinner than the original screws, if these nuts/bolts rust and break in the future, they'll just slide out and can then be easily replaced (why didn't Honda think of that?). Problem solved! :D |
| All times are GMT -8. The time now is 06:45 AM. |
