AC issues.
Old Oct 31, 2012 | 10:35 PM
hoskins4952's Avatar
Question AC issues.
2000 Honda Civic EX with 193000 miles. About 2 years ago I completely replaced the AC system. Recently the compressor locked up. I replaced it, vacuumed it out and charged it back up. However it is not blowing cold air, only moderately cool air. Does anybody have any suggestions as to what the problem might be? Thanks in advance...
Old Nov 1, 2012 | 06:21 AM
What are your operating pressures?
A blown compressor tends to clog up the condenser. Also if you replaced the TXV make sure the sensor line is properly installed and insulated.
Old Nov 1, 2012 | 02:57 PM
90 Civic's Avatar
Somewhere you have a filter/drier & an expansion valve. If you blew or seized a compressor I'm sure you have one or all of those plugged. Never change out a compressor with out changing the filter/drier. If you had a gauge hooked up you would of had a higher then normal high side reading I'm sure. But without both a high & low side reading who knows.
Old Nov 1, 2012 | 10:08 PM
Will get the reading and post them here...Thanks
Old Nov 2, 2012 | 12:09 PM
Default reading
The low side was at 5psi and the high side was at 50psi.
Old Nov 2, 2012 | 01:09 PM
Unless it is very cold out (A/C testing really needs to be done in warm weather), it is severely undercharged.
Old Nov 6, 2012 | 01:19 PM
90 Civic's Avatar
You have a leak somewhere. Normal pressure reading should be 30 low 150 high. They will vary from that depending on outside temps.
gillespiecd
Mar 21, 2005 03:48 PM
Mad7s
13
Mar 15, 2005 10:38 PM
Sharpshooter
Jan 6, 2005 07:07 PM
shorty3788
Nov 21, 2004 11:04 PM
daspoint
May 4, 2004 09:24 PM
