accelerator cable stuck, got pics
RE: accelerator cable stuck, got pics
Check at the throttle body to see if it binds or the springs on the throttle body are broken. If the throttle body lever springs back like it should, the cable is likely bad. Also there's a possibility the gas pedal got stuck on a floor mat or something.
If the car is equipped with those features, disconnect the cruise control and automatic transmission cables from the throttle body for that test.
Edit: Ok your picture shows the cable doesn't return even with the gas pedal back up, so it's not the gas pedal.
ORIGINAL: HuGGyBear305
last
[IMG]local://upfiles/29629/BA3FA680A27344DC93F3C7CFFBAAD0CF.jpg[/IMG]
last
