air conditioner only works below 70 degrees
Hey guys - I hope someone can help me out. I'm new here. I have a '95 Honda Civic hatchback, and the air only works when it's below 65 or 70 degrees outside. Anyone ever had this problem?
the compressor could be going bad, and not pumping as it should so it would not get as cool. or look at the condensor and see if it is plugged up with stuff and has bent fins. clean it out and it should help out a bit.
ORIGINAL: Pete
I think I have been DE modded. I cant move it......
...*Moved*
EF is prolly right, but check to make sure that the compressor clutch is engaging. If the compressor clutch is engaging and the A/C still doesnt' work, then its either the compressor or condensor. Is it possible that a temp sensor is malfunctioning and causing the clutch to not engnage?
Kevinminnick
Jul 18, 2006 07:15 PM
tonguetwiztid
Jun 27, 2005 09:08 PM
70, 70degrees, ac, air, airconditioner, belw, cinditioner, civic, conditioner, degrees, doesnt, honda, run, work, works
