All 4 cylinders misfiring
I have a 98 civic LX, just had the timing belt changed last year, for the last month has started misfiring. I put the scanner on, got these codes: P0301, 0302, 0303, 0304 and 0300. All four cylinders misfiring with a random misfire to boot, lol.
I'm wondering if it slipped time, as in the timing belt slipped a cog? Or if it is a vacuum leak somewhere, probably into the intake manifold, that is causing this? I changed the plugs and wires and distributor cap, but it wasnt the issue. Any thoughts on what it might be, and what to check next? |
did you replace the rotor with the Dist. cap? (if not, it would be a good idea)
I think that it would be best to double-check that the timing is set right (just to verify that the timing belt didn't jump a cog) |
Yes, replaced the rotor when i did the cap. Am wondering if it might not be a vacuum leak?
if its gettin spark and fuel, it has to be the timing... if it was a vacuum leak, your car would just idle all retarded
Also check the coil and ICM inside the distributor.
How does the rotor look? |
