HondaCivicForum.com
-   -   antenna reception (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/antenna-reception-88851/)
hobbsy3005 May 12, 2011 07:17 AM
antenna reception
is there any way to boost your antenna reception? it get blocked by houses, trees, and small buildings all the time. would buying a new one make it better? or maybe some trick to get more power to it?
mk378 May 12, 2011 10:00 AM
Is the antenna all the way out? Also look under the dash and make sure that the antenna cable is actually plugged into the radio.
If your car has the pull-out antenna by the door it is not expensive to replace but reception problems are often with the radio.
hobbsy3005 May 16, 2011 10:41 AM
yes its a pull out and it is always pulled out. im getting a new deck in the next couple days so ill make sure it plugged in all the way when i install it. if that doesnt work then ill probably just buy a new one
