HondaCivicForum.com
-   -   anything I can do about this (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/anything-i-can-do-about-48762/)
ic892003 Jul 26, 2007 05:37 AM
My clutch pedal is real squeaky when I push it down, anything I can do?
AgentofDarkness Jul 26, 2007 06:00 AM
RE: anything I can do about this
Grease it with some white grease
ic892003 Jul 26, 2007 06:16 AM
The pedal it self from the inside of the car??? Could I use wd40 instead
AgentofDarkness Jul 26, 2007 10:17 AM
The pedal is most likely on a hinge, so it can pivot and what not. You can use WD-40 but it doesn't stick around since its so thin. If you use white grease, which is thicker, it will stick in the hinge much longer.
cyberx32 Jul 26, 2007 07:51 PM
Actually it might be your clutch. Is your pedal kinda hard to press? i have the same problem and i took it to the mechanic, and he said the clutch is going out.
AgentofDarkness Jul 26, 2007 09:09 PM
Always start with the simple stuff first. A can of white grease costs like $5.00.
Masonn Jul 27, 2007 12:36 AM
+1 to WD40!!!
cyberx32 Jul 27, 2007 10:45 AM
yeah i guess. I only mentioned it cause i used wd40 and the squeek is still there.
