b18a1 swap, now the wheels dont spin...
Old Sep 5, 2006 | 07:38 PM
b8teen's Avatar
Default b18a1 swap, now the wheels dont spin...
I just put a 93 integra motor into my 91 hb. everything is in and it runs fine, but the wheels dont move. they try to, but they dont go anywhere. i thiught it was the trany, so i bought a new one, put it in. still the same problem. can anybody help? please.
Old Sep 5, 2006 | 08:28 PM
windcalmer's Avatar
Default RE: b18a1 swap, now the wheels dont spin...
Did you double and triple check everything? Not that I think that you are dumb, but are the axles the right ones and hooked up the right way? Is there Tranny fuild in the tranny? Is it an Auto or Manual?
Old Sep 5, 2006 | 08:38 PM
b8teen's Avatar
its a manual, the only thing that i can think of is that the axles look slightly crooked, but i did double check everything. also i think that the motor mounts might be wrong, causing to much pressure on the axles. but i need someone w/ more expertise to help me out.
Old Sep 5, 2006 | 08:57 PM
windcalmer's Avatar
If you can post pics of your setup (as many as you can, trying to show the mounts and everything) I know that will help some of the smarter guys figure this one out. So rry I couldn't help. Good luck.
Old Sep 5, 2006 | 09:03 PM
sacicons's Avatar
bad clutch? will it roll in neutral?
Old Sep 5, 2006 | 09:16 PM
fglaustin's Avatar
when the front wheels are jacked up - what does it do in that position.
Old Sep 5, 2006 | 09:18 PM
b8teen's Avatar
no wont spin in neutral im stumpped
Old Sep 5, 2006 | 09:19 PM
fglaustin's Avatar
well, put it in first with the front wheels jacked up
Old Sep 5, 2006 | 09:20 PM
b8teen's Avatar
when jacked up axle will spin and wheel will spin but when to are connected they don't move :<
Old Sep 5, 2006 | 09:21 PM
fglaustin's Avatar
did you swap the clutch into the new transmission
