bad gas mileage
Old Feb 7, 2008 | 04:30 PM
98civkmik's Avatar
Default bad gas mileage
so i drive a 98 hx, which is supposed to have close to the best gas mileage right?
well with intake header and exhaust I'm getting like less then twenty five miles per gallon, does anyone know what could be causing this decline in Mpg?
I do have an exhaust leak on the downpipe of my header would that be causing it, and is there anything else that could effect it?
thanks
Old Feb 7, 2008 | 05:24 PM
chisox64's Avatar
Default RE: bad gas mileage
Could be a lot of things. Is it cold where you live? Cold weather and winter gas blends will drastically lower your mileage. Mine went from 30 (city) to 26 when the temps dropped consistantly under 20F. Do you drive the car hard? Your not going to get 30+ if your putting your foot through the floor or if you're in stop and go traffic. You could also check the air filter, gas filter, spark plugs, injectors...
Old Feb 7, 2008 | 07:02 PM
The exhaust leak is likely interfering with proper functioning of the oxygen sensor and causing the bad gas mileage.
Gen5unknown
26
Jan 9, 2008 10:00 PM
Live_4it
Mar 13, 2007 04:57 PM
dee1
Jul 27, 2006 10:42 AM
civic x
May 16, 2006 02:16 PM
96civicexer
Jan 17, 2006 01:31 PM
