bad tps ?'s
Old Aug 24, 2007 | 11:14 AM
nik005's Avatar
Default bad tps ?'s
so im thinkin that my surging idle problem is a bad tps cause it only surges after reaching operating temp and its not just an idle surge it will surge at other times when ur accelerating or just cruising but the computer has no cel so does that mean it cant be the tps? but if it is the tps then do i really have to buy a whole new throttle body cause someone told me u cant just replace the tps u need the whole throttle body with a good tps already on it?
Old Aug 24, 2007 | 09:42 PM
AgentofDarkness's Avatar
Default RE: bad tps ?'s
I believe the TPS is riveted onto the throttle body so it might be hard to replace just the TPS. If you want to make sure the TPS is the problem, get a scan tool that can read live sensor data. Hook up the scan tool and look at the TPS data while the engine is surging. If you see something that is not correct (like the voltage is jumping around) then you will know for sure that the TPS has a problem.
Old Aug 24, 2007 | 11:48 PM
Ej1Rider's Avatar
yeah the tps is riveted to the tb, but the rivet is a couple of screws basically with no head, what you can do is get a rotary tool, put a cutting disc to it and cut a slit on the head of the rivet, forming a flat head slit that a flat head screwdriver can fit in, then you can screw it out
Old Aug 28, 2007 | 11:20 AM
EightyNineDX's Avatar
Forty04 told me to use a hack saw to get those bad boys out then use regular screws when replaced ... im having the EXACT same proble as you man, im gettin my done tomorrow morn, will let you know if it works for me so you can get rid of your irratic idle too!
Old Aug 28, 2007 | 05:50 PM
skibum853's Avatar
FYI....a good place to get a good one is inlinefour.com. just bought a brand new one. if you go to the honda dealer, thay make you buy the throttle body too. and the screws are just a normal metric thread so you can pic them up at most hardware stores, or a bolt supply store.
Old Aug 28, 2007 | 06:07 PM
nik005's Avatar
thanks for the replies guys but my tps fixed itself somehow but that was definatly the problem cause when u disconnect teh tps the computer will use a default for that sensor so i did that and the idle was fine just really high but then right when i plugged it back in it was surging again but today it just somehow stopped'
Old Aug 29, 2007 | 04:05 AM
Well, you can expect the problem to come back soon, so be prepared for it. Have you tried checking the TPS to be sure its calibrated correctly?
Old Aug 29, 2007 | 04:06 AM
nik005's Avatar
i dont even know what calibrating the tps means so no
Old Aug 29, 2007 | 04:13 AM
Do you have a manual?
ryan62586
May 16, 2018 10:57 AM
skimmy_jimmy
Mar 1, 2007 11:04 AM
ef4life
ED-EF Swaps
16
Jan 25, 2006 04:51 PM
cmasonrun
Jan 12, 2006 11:25 PM
fast93civic
Jun 11, 2005 10:19 PM
