Bad TPS? Transmission shifts late and hard.
Old Dec 9, 2013 | 03:24 PM
Jymmm's Avatar
Originally Posted by simply78
Ryan - I have a 2001 Civic with the same issue but I don't understand the acronyms and jargon...
CEL - Check Engine Light
The light on the dash that should ALWAYS turn on momentarily when you turn the key on as a bulb test, and there after if/when there is an issue that needs to be addressed.
TPS - Throttle Position sensor
Used to monitor the position of the throttle in an internal combustion engine. The sensor is usually located on the butterfly spindle/shaft so that it can directly monitor the position of the throttle.
ECU - Electronic Control Unit (the car's computer).
ECM - Electronic Control Module (again, the car's computer).
VSS - Vehicle Speed sensor
Measures transmission/ transaxle output or wheel speed. The ECM uses this information to modify engine functions such as ignition timing, AF ratio, transmission shift points, and to initiate diagnostic routines.
Old May 16, 2018 | 10:57 AM
Cycocap's Avatar
Default Same problem, how do I fix it!?
I am having this exact same problem with my 95 Civic ex coupe, shifts hard and at too high RPM . Can anyone give me an exact walkthrough on how to correct this?
-98.Honda.Civic.Lx-
Aug 27, 2012 11:28 AM
Drew W
May 3, 2010 01:58 PM
scalezy3b811
Jan 24, 2010 08:18 AM
dabazi22
Aug 22, 2009 03:03 PM
killerformula
14
Sep 9, 2008 07:27 PM
