HondaCivicForum.com
-   -   BATTERY OR ALTERNATOR?? (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/battery-alternator-50728/)
basbal123 Aug 26, 2007 07:56 AM
Ok,i was driving around yesterday and then all of a sudden my hid lights started flickering like a strobe light and then boom there gone, my radio wouldnt work, and i definently couldnt start the car over again after that, so how do i know if the battery is bad or my alternator isnt working??
noshowallgo Aug 26, 2007 07:59 AM
RE: BATTERY OR ALTERNATOR??
se if you can start the car and if it starts then after like 15 to 2min it cuts off then i would think altenater or altenater belt also take your battery to autozone or someplace like that and they ddo free battery testing.
basbal123 Aug 26, 2007 08:00 AM
like yesterday i had to pop the clutch but after that i didnt have a problem with it running i just couldnt run anything like the radio or my head lights
kinosh Aug 26, 2007 08:05 AM
Take the battery to Autozone and have it tested. If it's holding a charge, you have a bad alternator.
Another sign it's the alternator is that your battery warning light on the dash should have been lit for about 30 min (with your headlights on) before the headlights started flickering.
noshowallgo Aug 26, 2007 08:07 AM
yeah man just get the battery tested
AgentofDarkness Aug 26, 2007 09:13 AM
Easy way to tell if your battery is bad or the alternator is to check the voltage at the battery while the engine is running. If the voltage is under 13.5V, the problem is the alternator. You can try taking the battery into AutoZone, but they usually do battery load tests which requires the battery to be charged.
cordobess Aug 26, 2007 03:32 PM
the best way to check ur alternator.. is.. turning of ur engine. when u got ur engine start. disconnect the positive of the batery.. if the car die.. the problem is the alternator, if the car stay on when u disconnect the batery.. the problem is the batery.. if u take the positive of and the alternator is good.. u engine keep running.
addiction2bass Aug 26, 2007 04:39 PM
DO NOT DO THAT!!!!!!!!
if you pull off the battery wire you will destroy the alternator!!!
DONT DO IT... thats the redneck way of testing which puts a huge load on the alternator! dont be stupid!
recharge the battery fully! then if a autozone or another autoparts store is close enough to you if you can drive thier with nothing BUT the motor runing and have them test the alternator and battery....
BUT most likely its your alternator.....
cause if it was a bad battery it wouldnt start overnight but if it was the alternator then it would cause your car to shut down during driving!
basbal123 Aug 26, 2007 06:50 PM
like the car didnt shut down, but i could run the headlights or anything
AgentofDarkness Aug 26, 2007 06:54 PM
Do the voltmeter test if you can turn the engine on and have a meter. Its is the easiest test as it takes about 25 sec and will tell you the problem for sure.
