dash light (97 ex)
Old 10-24-2008, 07:33 PM
codered3x's Avatar
Default dash light (97 ex)
i was driving last night and both the dash lights and automatic shifter lights went out at the same time... i checked a lot of fuses and didn't find one broken... if it is a fuse what would it be labeled and if not what could it be.
Old 10-24-2008, 07:45 PM
Check for a blown fuse #30 (7.5A) under the dash.
Old 10-24-2008, 08:09 PM
codered3x's Avatar
i put a new one in and started up the car and turned on the lights and it busted instantly.. then i tried another with the same result... and explanation
Old 10-24-2008, 08:18 PM
You obviously have an electrical short. I think the dash lights brightness controller is a prime suspect.
Old 10-24-2008, 08:23 PM
codered3x's Avatar
could it have anything to do with my own personal stereo installation ... btw the dimmer has never worked for me so you might be right
Old 10-24-2008, 08:26 PM
Possibly. Depends on how you wire the stereo in. The stock radio light is tied into this circuit
Old 10-24-2008, 08:33 PM
codered3x's Avatar
thanks for all your help
Old 10-24-2008, 08:34 PM
No problem. Let us know how it turns out.
Old 10-25-2008, 02:03 PM
codered3x's Avatar
i got the controller out and disconnected it and none of the wires or prongs look bad... how can i test this further?
Old 10-25-2008, 02:10 PM
mundy5's Avatar
who installed your stereo? I would start there. If the stereo is not properly grounded, it will blow other fuses.
Quick Reply: dash light (97 ex)
