Best Place to Use Hydraulic Jack for 2002 Honda Civic LX
Old Sep 7, 2012 | 01:08 PM
DAC's Avatar
DAC
Default Best Place to Use Hydraulic Jack for 2002 Honda Civic LX
I am seeking to enter a mechanical milestone, changing my own oil and oil filter. I purchased both a 2-ton hydraulic jack and 4-ton jack stands--both at Autozone--for the job.
Where's the best place under the car to use the hydraulic jack (beyond the areas specified in the manual) without crushing or crunching anything, so then I can put the jack stands on the sides?
I have a 2002 Honda Civic LX.
Thanks in advance (and as you can all guess), I'm a little knew at this, though I've gotten more experienced as I've learned to do simple stuff I use to rely on garages.
Old Sep 7, 2012 | 01:48 PM
I would only jack the car up from the OEM spots. Should be one on each side behind the tires, and possibly one under the radiator support in the front. I suggest the front jacking point, and placing jacks where the control arms meet the subframe.
That's what I do at least.
Good luck!
Old Sep 7, 2012 | 09:05 PM
rekomstop209's Avatar
You could just buy ramps instead and then not have to mess with the jack ever.
Old Sep 8, 2012 | 10:51 AM
+1 on ramps being great for oil changes. Very quick and safe. Of course if you need to do something that involves taking a wheel off, ramps won't work.
briceman124
Sep 20, 2011 08:46 AM
Ska-T
Apr 21, 2010 12:21 PM
snosurfa7
Feb 11, 2009 06:33 PM
civicexracer
Oct 3, 2007 07:36 PM
ltkenbo
Nov 28, 2006 06:50 PM
