HondaCivicForum.com
-   -   Best Place to Use Hydraulic Jack for 2002 Honda Civic LX (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/best-place-use-hydraulic-jack-2002-honda-civic-lx-94105/)
DAC Sep 7, 2012 01:08 PM
I am seeking to enter a mechanical milestone, changing my own oil and oil filter. I purchased both a 2-ton hydraulic jack and 4-ton jack stands--both at Autozone--for the job.
Where's the best place under the car to use the hydraulic jack (beyond the areas specified in the manual) without crushing or crunching anything, so then I can put the jack stands on the sides?
I have a 2002 Honda Civic LX.
Thanks in advance (and as you can all guess), I'm a little knew at this, though I've gotten more experienced as I've learned to do simple stuff I use to rely on garages.
cvcrcr99 Sep 7, 2012 01:48 PM
I would only jack the car up from the OEM spots. Should be one on each side behind the tires, and possibly one under the radiator support in the front. I suggest the front jacking point, and placing jacks where the control arms meet the subframe.
That's what I do at least.
Good luck!
rekomstop209 Sep 7, 2012 09:05 PM
You could just buy ramps instead and then not have to mess with the jack ever.
mk378 Sep 8, 2012 10:51 AM
+1 on ramps being great for oil changes. Very quick and safe. Of course if you need to do something that involves taking a wheel off, ramps won't work.
