Brake and Gas Pedal Removal
I converted my Civic from AT to MT but I still have the brake and gas pedal assembly.. how easy will it be to remove the brake and gas pedal????
I had to pretty much finish the AT to MT swap on the teg. Clutch pedal is cake compared to the brake pedal. Just a VERY tight area to work in.
If you think of it, can you take a picture of where the return spring from the pedal hooks onto the bracket? I haven't done that yet and it is a PITA to drive with like that. Brake pedal should only be 3 things: the top bolt (which it pivots on), bolt or clip (cant remember) for the pin connecting it to the BB/MC, and the return spring. Are you swapping to a MT harness for the clutch safety switch etc? |
Consider removing the dash first, it's not as complicated as it seems.
