HondaCivicForum.com
-   -   Brake light on dashboard lights up when I make some turns. (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/brake-light-dashboard-lights-up-when-i-make-some-turns-95496/)
DaHonDa Jul 9, 2013 12:15 PM
When I make turns, the brake light on my dashboard (the light that tells you whether the hand-brake is on) lights up. It seems that the turns that make the brake indicator light up are sharper turns.
When I put my hand on the hand-brake, I can confirm that the hand-brake is on the down position. After some time, the brake-light on the dashboard turns off.
What's going on?
Civic currently has 326,000 km or 202,567 miles
mk378 Jul 9, 2013 12:42 PM
The brake fluid level is low. When you turn, it sloshes around and trips the switch.
DaHonDa Jul 10, 2013 09:53 AM
Thanks mk378,
the brake fluid was quite low, and I topped it up with Penzoil DOT3 and Gunk (what a name!) DOT3.
