brake light/directional problems. PLEASE HELP!
1992 civic dx hatchback. The brake lights work, but the 3rd light is bright and the other two are really dim, as well as the fact that the driver's side rear directional does not work. When I turn on the headlights, the 3rd brake light goes on and the other brake lights don't work at all. Anyone out there have some advice as far as where to look? I've tried everything I can think of and I'm getting nowhere fast.
The bulbs on the sides have lost their connection to ground. Either the sockets are corroded or the ground wiring is bad. This causes the brake and tail light circuits to interact like you described.
On hatchbacks it is common for the wires to break where they go between the hatch and the main body of the car, since they flex there every time the hatch is opened. The outer appearance of the wire may be OK but the copper inside breaks. |
Reload this Page brake light/directional problems. PLEASE HELP!
Originally Posted by mk378
(Post 789587)
I've also tried to set up an independent ground on on both sides and also swapped the rear light harnesses which didn't change anything
Ground wires are almost always black. I think this is the case here. You can also test voltage from the shell of the bulb to a good ground, with the light on, the voltage should be near zero if the bulb is grounded.
| All times are GMT -8. The time now is 05:26 AM. |
