brake lights stay on while car is off
Old Jan 23, 2007 | 06:35 PM
1994hondacivicbrando's Avatar
Default brake lights stay on while car is off
When leaving work today I noticed that my battery dead, upon further inspection i realized that my brake lights were staying on while the car was off? any suggestions on how to fix this? thanks
B
Old Jan 23, 2007 | 06:54 PM
Stumasters's Avatar
Default RE: brake lights stay on while car is off
Sounds like an issue with the brake lever somehow. There should be a switch down there that activates the brake lights, somehow its getting stuck, or maybe the pedal itself is sticking a little, and not extending fully to depress the switch that triggers the brake lights.
Might try looking around in that area, and see what you find. I will see if I can't find something else somewhere to help.
Old Jan 23, 2007 | 07:12 PM
Red Hot Rider's Avatar
Yup, check the switch at the pedal. Might just have some crap stuck in it. Fiddle with it, maybe some compressed air or something. If still faulty, replace it.
Old Jan 23, 2007 | 07:23 PM
i think that the brake pedal button broke, I found small back pieces on my floor mat that look like they would fit in a hole at the top of the pedal pushing in a button on what looked like a relay, is this plastic part hard to find or install, could this be the problem?
Old Jan 23, 2007 | 07:42 PM
Misha's Avatar
Should cost a couple of bucks at a dealer...
Old Jan 23, 2007 | 07:49 PM
yup, dat's the problem. list price of $17.62, stop switch assembly.
Old Jan 23, 2007 | 07:53 PM
Misha's Avatar
Actually my data show OEM switch at $52.57 list. But i think it's just the pad on the pedal what needs to be replaced, which is $1.92
thanks so much!!
Old Apr 22, 2008 | 02:47 AM
natas915's Avatar
Unfortunatley I too am now expirencing this problem and the Plastic part that pushes in the stop switch relay is broken, do you have the name for this part, because I cant find it.
<center>
<img src="http://i30.photobucket.com/albums/c3...13SR80_B23.gif" alt="Photobucket - Video and Image Hosting"><br><br>
</center>
Product No.
Illust.No. Reqd.
105280 001 1 PEDAL, ACCELERATOR
5895 0032 WASHER, ACCELERATOR PEDAL
105282 0041 SPRING, ACCELERATOR RETURN
10985 005 1 COVER, ACCELERATOR PEDAL
107395 006 1 COVER, RETURN SPRING
105283 007 1 ARM, AUTO CRUISE
22802008 2 BUSH, CENTER
22803 009 1 SPRING, AUTO CRUISE :
105286 010 1 WIRE, ACTUATOR
105293 012 1 WIRE, THROTTLE
17744 013 2 SEAL, THROTTLE CABLE
22808 014 1 CLAMP, THROTTLE WIRE
86684 0161 STAY, THROTTLE WIRE
105297017 1 SWITCH ASSY., STOP & CRUISE
22812 018 1 SWITCH ASSY., CLUTCH (INHIBITER)
22815 019 1 SWITCH ASSY., CLUTCH (TEC)
107396 020 1 PEDAL ASSY., BRAKE
22818 022 4 BUSH, PEDAL
5905 023 3 PAD, PEDAL STOPPER :
22820 024 1 SPRING ASSY., PEDAL RETURN
22821 025 2 COLLAR, PEDAL
22822 027 2 COVER, PEDAL
107400 028 1 BRACKET, PEDAL:
97911 029 1 PAD, ACCELERATOR STOPPER :
22837 030 1 STOPPER, CLUTCH PEDAL
22825 032 1 SPRING, CLUTCH ASSISTANT
4845227 0331 PEDAL, CLUTCH
22827 034 1 BUSH, PEDAL PIN
22828 0352 BUSH A, CLUTCH ASSISTANT
22829 0361 BUSH B, CLUTCH ASSISTANT
22830 037 1 BRACKET, CLUTCH PEDAL
22831 0381 BRACKET, FOOTREST
6211 039 2 NUT, FLANGE (10MM)
22832 041&nbsp
Old Apr 22, 2008 | 05:57 AM
Misha's Avatar
On your list
