HondaCivicForum.com
-   -   brakes acting ignorant (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/brakes-acting-ignorant-58846/)
GangstaMas1 Jan 13, 2008 08:11 PM
After installing new pads the pedal goes almost all the way to the floor what could that be?
RonJ Jan 13, 2008 08:17 PM
RE: brakes acting ignorant
Your front caliper or rear wheel cylinder has a leak. Alternatively, your brake master cylinder has failed. Look for brake fluid leaks.
GangstaMas1 Jan 13, 2008 08:19 PM
that makes sense thanks
RonJ Jan 13, 2008 08:33 PM
The location of the brake fluid leak will be highly informative.
Firehawk989 Jan 14, 2008 09:23 AM
I think its far more likely that you just need to bleed your brakes, especially if they were working fine before you changed the pads. The tiniest bubble of air in the lines can cause these symptoms, happened to me when I changed my pads and rotors. You just go to the auto parts store and buy a brake bleed kit for like $10 or $15 bucks and follow the instructions, its pretty simple. Buy some Honda brake fluid as well since you might use up a bit when you bleed them.
reconstyle Jan 14, 2008 09:50 AM
A brake bleed kit? All you need is a bottle of brake fluid, a piece of tubing, and a friend.
My04Civic Jan 14, 2008 09:56 AM
bleed the brakes...i had the same problem...so go back and keep bleeding. it sucks, i know. you need 2 people
