HondaCivicForum.com
-   -   broken bolt (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/broken-bolt-22261/)
rice_patrol May 18, 2006 07:06 PM
broken bolt
the bold from my downpipe is broken. Half of it is still in there and cant take it out. even with a impact wrench and a reg. wrench. I tried but i cant get it out. Any suggestions for me, i dont want to take it in to the muffler shop. well hope that helps. thanks.
http://img.photobucket.com/albums/v6...y/DSCF2396.jpg
DanH May 18, 2006 07:19 PM
RE: broken bolt
You could try an easy-out. If you don't know what one is just go to google.com andenter "easy-out".
AgentofDarkness May 18, 2006 07:58 PM
RE: broken bolt
I'm thinking that you could drill out the bolt/stud that is in the pipe and put in a bigger bolt with a washer and a nut. For next time, WD-40 is your friend, i learned that the hard way.
Patrick May 18, 2006 08:42 PM
RE: broken bolt
whats a down pipe? the only down pipe that i know of is on turbo cars...do you mean off of your exhaust manifold? is that the head, or the end? and is it in a threaded piece, or is it just rusted in place?
Fiirkan May 18, 2006 09:25 PM
RE: broken bolt
Go to an autoparts store and bet one of those blow torches, heat the bolt up just enought so that it starts to turn red... but DO NOT let it melt..then use a wrench and vouala it should come out.... in theory
AgentofDarkness May 18, 2006 09:36 PM
RE: broken bolt
That torch is like $250, if its propane it prolly won't have enough heat you need a Oxy/Acetelyne torch. I don't think you are suppose to let it get red hot.
Fiirkan May 18, 2006 09:39 PM
RE: broken bolt
^ yeah i was refering to the propane ones... it was mainly an idea that popped into my head just then i didn't really think about it... and when i said starts to turn red, i meant that once you see red developing to stop heating it.. and the propane ones are only like $15-20.. so it isn't like it is a big investment for it... worth a shot i'd say
Forty04 May 19, 2006 06:56 AM
RE: broken bolt
Coat it in PB Blaster, let it sit for a few minutes, then heat with a torch and try the impact gun again. If that doesn't work, your only other options are drilling, or an easy out, and those things are teh ghey
rice_patrol May 19, 2006 08:33 AM
RE: broken bolt
Thanks guys. Ill try that after school. if it doesnt work then ill just go to milwaukee and tell my uncle to see what he can do. I have to go to milwaukee anyways. Well thanks for the tip. Will sure try some.
AgentofDarkness May 19, 2006 11:59 PM
RE: broken bolt
ORIGINAL: Fiirkan
No offense but those propane ones really suck. I have one that my dad used to use for plumbing so i was using it on my axle nut that i couldn't get off. I got the propane torch out and heated it forever and it didn't budge. I was telling my teacher about it (he's been doin this for like 40 years) and he said that a propane torch will never be able to get hot enough to sufficiently heat a bolt. So i would stay away from the and get an Oxy/Acetelyne torch. But they are expensive as hell, brand new they run like $280 for a port-a-torch. I have only found one used one, the guy was asking more than a new torch.
