A/C belt squeal
Hit the A/C on my 97 4door civic lx and it squeals like a pig! Quiets down after a few minutes, but the belt feels a bit loose. How do you adjust the a/c belt? How about the other belts? Might as well check them all. I see what looks like an ajdustment screw right on top, near the valve cover, but can't really tell where the bolts are to loosen the pieces so they can be adjusted.
Thx
Thx
Loosen (do not remove) the nut on the idler pulley and turn the long jack screw that goes to the idler pulley axle to tighten the belt. Then tighten the nut.
Only the A/C has an idler pulley. The power steering and alternator belts are adjusted by moving the pump or the alternator respectively.
If the belt has been squeeling for awhile, you may need to replace the belt. Sometimes the belt will get glazed and it will have a tendency to squeel. If you decide not to replace the belt be carefulwith thebelt tension.
If you have power steering may be easier to work on it from underneath. You will need a 14mm end wrench on that nut, socket won't fit. You could also remove the power steering pump to make the A/C parts easier to reach. Unbolt the pump from the engine but don't disconnect the fluid lines, and push it aside.
shelzmike
Sep 28, 2010 10:00 AM
