a/c drain hose location
My 2002 Civic has a water problem on the passenger side floor. I know it is coming form the A/C as it only happens when the A/C is on. Doing research it appears that the A/C drain hose is clogged. The fix is to blow some up the hose or use a wire to clear the clog. But, I can't find the drain hose. Can anyone help? I need to know where the hose is.
http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&catcgry1=Civic&catcgry 2=2002&catcgry3=2DR EX&catcgry4=KA5MT&catcgry5=HEATER UNIT
#22 on the drawing
#22 on the drawing
If you get under the car and look at the bottom of the firewall, you will see the drain hose coming out through the firewall and down passenger side. Thats how it works for an Accord, so it's worth a try.
soundquest
Jul 27, 2021 08:23 AM
superfestiva
13
May 26, 2006 04:20 PM
