A/C dye from drain hose???
Old Jun 22, 2007 | 08:18 AM
01bmf's Avatar
Default A/C dye from drain hose???
I have A/C dye dripping from the drain hose. Is this normal? If not, how would I stop that?
Old Jun 22, 2007 | 10:32 AM
Default RE: A/C dye from drain hose???
There's a leak, most likely the evaporator itself but sometimes something else in the evaporator box, which you will soon confirm when the A/C stops working.
Fortunately it is quite easy to remove the A/C box from the car and replace the leaky part, compared to most American cars where the whole dashboard must be removed to work on the evaporator.
The other possibilty, if you just acquired the car, is there was a leak which has been fixed but there was some dye left in the box.
Old Jun 22, 2007 | 12:43 PM
01bmf's Avatar
Thanks. I pulled out the evaporator. It was plugged with crap and leaking all over. That was a lot easier to remove than I expected.
Hailchristian
Sep 16, 2007 03:37 AM
TIcivic00
Aug 27, 2007 09:23 PM
chuck_sparrow
Nov 21, 2006 08:52 PM
Froznface
Oct 12, 2006 07:21 AM
hoodlum
Aug 13, 2004 01:04 PM
