Cam shaft 180 degrees off
Old Apr 14, 2007 | 09:52 AM
Cosmo's Avatar
Default Cam shaft 180 degrees off
I had a local mechanic replace the head gasket on my 1990 civic. The engine is a replacement D15B2 supposedly from Japan. The mechanic said that the directions for installing the camshaft were 180 degrees from the way it was when he took it out. He followed the directions. The timing mark is now at the bottom position when timing from cylinder No. 1. The car starts fine and runs OK but is lower on power than before this work. My question is: Does it matter on this engine whether the cam is 180 degrees off?
Thanks
Cosmo
Old Apr 15, 2007 | 08:12 AM
Default RE: Cam shaft 180 degrees off
yes it does matter. When you set the motor to TDC, is the cam pully arrow pointing up?
Is the timing set correctly
Old Apr 15, 2007 | 06:25 PM
Cosmo's Avatar
The timing marks are pointing down. Since the firing order is 1 4 3 2, can you time from cylinder number 2 if the crank and cam are 180 degrees out? I don't think this car has a cam position sensor, so what difference does it make if the cam is 180 degrees out? I assume the car fires on the compression and exhaust strokes since it has a regular distributor.
Thanks
Cletus
Old Apr 15, 2007 | 09:52 PM
riceburner700's Avatar
im suprised the car even runs with the timing 180 degrees off!
wompx3
Feb 9, 2012 11:25 PM
Eclipse 2K
Apr 13, 2008 07:37 PM
NoRice
Sep 14, 2007 05:56 PM
JDMracer00
Oct 24, 2005 11:24 PM
Pete
Oct 13, 2005 11:32 PM
