Honda civic (1995) EX has no fuel or spark
I have a 1995 honda civic. Automatic non v tec. About2 weeks ago i drove to a friends house then upon leaving discovered i had no fuel. The pump wasn't making its usual buzzing and the gas i had just put in did no good. I came back a few days later to tow it and it fired right upon. Parked it in front of my house on the way home and it would mot start again. The coil tests fine, there is no spark however. It wont prime with the key either.
The main relay has been switched and all fuses look good although i did not check the square box fuses under the hood up front just the traditional looking fuses.
The power coming from the main relay that goes though the yellow black wire or what i think is the feed wire gets 9.11 volts at alltimes. The ground wires on a23, a24 and a26 all check good.
Ive been told the green yellow wire from behind the computer feeds the coil but that wire is dead.
What needs to be checked to solve this?
Red_Devil
06-16-2012 09:38 AM
her98civicex
06-04-2010 11:48 AM
katies95
12-18-2006 04:07 PM
