Can you repair axles??
OK, the drivers side axle i got with my swap has all the threads on the spindle just destroyed. well i have some good axles for civics lying around but they wont fit my engine (halfshaft is different). so i was wondering if its possible to take the spindle from the good one and put it on the bad one??? i really hope so cuze it turns out that because of the halfshaft being different on the b16b from most other usdm civics that it almost looks like im going to have to order one from japan or something. sounds really expensive to me
RE: Can you repair axles??
Go to advanced auto parts or where ever and get a axle for a 99/00 Integra type r
The wheel spindle and outer joint cup are one piece. If the other axle has a bad outer joint there's nothing you could do, since both spindle/cup units are bad.
You can switch the inner joints pretty simply though. |
ok, what i have is 3 good axles from various civics, then i have the one with the messed up threads that came with the motor. can the cup and spindle from one of the good ones be swapped with the bad cupspindle?
The outer joint isn't intended to be taken apart in the field. Obviously it must come apart somehow...
But if you have one with the right length axle you might be able to switch the inner joint to have the transmission shaft be the right one for your transmission. |
ORIGINAL: mk378 The outer joint isn't intended to be taken apart in the field. Obviously it must come apart somehow... All US 94-01 Integra and 99-00 Si axles are interchangeable. Some of the later JDM Integra used larger 36mm axles, but if yours are 32mm then you can use any of the above. |
sweet thanks for the help. ordered a new drivers side one for a 99 civic si today. only cost me 130. was kinda suprised. thanks for the help again guys
where did you buy it? if it's from a parts store you can probably return the bad one and get a core deposit back
i bought it from honda direct and i got the core out of the old one
