car over heating.
Hey guys my cars been overheating for a little while now. only when i go full throttle thru like 4 1/2 gears. im not sure what it could be. its not the thermo,and i dont believe its the headgasket. the fan comes on. antifreeze fills up the overflow and leaks out. thanks
hey i had a simalar problem with my mazda mx-6 and we couldnt find the problem, everytime we would drive it the temp would redline
so we took it to a shop an they said a rat chewd a wire...so that might be it, or maybe a short.has to be somthing electrical, an a coolant flush helps..
hope that helped
hope that helped
had the exact same problem. cars in the shop getting a new cylinder head. ask a local mechanic to do a block check. its a chemical check to see if theres Carbon Monoxide in yoru coolant...aka exhaust. its only about 35 bucks but it could save you money in the long run.
thanks for all the help. does anyone know anything about a blockguards? because i read that they restric coolant flow. and we all know d series need all the coolat they can get. if i drive it normal it will last forever without over heating. as soon as i start grabbin gears it starts to get hot. after it starts to get hot i put it in neutral and coast it doesnt go down. but if i hold it at like 2500 rpms in neutral it drops immediatley. it sounds to me like a coolant flow problem. but im taking out the block guard this week and while i have it off ill get the head checked
stylus
Jun 11, 2006 07:46 PM
