HondaCivicForum.com
-   -   Car stalls...why? (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/car-stalls-why-79389/)
PNK SLP Nov 7, 2009 05:14 PM
Car stalls...why?
Hoping ill get some help on this
My car has been running pretty good so far, no problems. runs strong..etc. I was driving around today and my car just stalled on me 3times in about 15min. I was just driving around 30-45mph and when i would push in the clutch to slow down or just go in to neutral my car would just stall on me. Normally the car motor will catch and idle at about 1000rpms.
I just change the plugs last week so i doubt that could have anything to do with it.
i know there could be few things to cause this and most people on here are not mechanics but maybe somebody might know why.
thanks guys
94civichatchback Nov 7, 2009 07:12 PM
clean your iacv see if that helps, also check your timing with a timing light.
PNK SLP Nov 7, 2009 08:28 PM
would the timing randomly go bad or outa of spec?
also my idle is fine
harleystcool Nov 8, 2009 12:53 AM
that happened to me with my old 94 ford escort, someone told me i might have had bad gas, the gas station might have had water in it, but i changed the air filter and it never happend again.
mk378 Nov 8, 2009 07:57 AM
If it runs good when in gear driving and the only problem is that it won't idle, it's usually the IACV. They can get sticky so they work sometimes but not others.
PNK SLP Nov 8, 2009 09:47 AM
i doubt its bad gas. i just filled up with sunoco 93 i ether run that or the shell V-power. But ill look into the IACV. thanks guys
