Car stuck in open loop
Old May 10, 2011 | 08:48 AM
Infinitrium's Avatar
Default Car stuck in open loop
I've been using my brother's Scangauge2 on my D16Y7-equipped 98 Civic and yesterday I noticed it showed that my car never goes into closed loop operation. I wonder if this is related to my P0135 code? The car still gets pretty good fuel mileage although I think it could be a little bit better. Also, I don't know if it's related to being stuck in open loop, I notice the car seems to be lacking in low end power.
Old May 10, 2011 | 08:58 AM
Closed loop operation means that the ECU takes readings from the primary oxygen sensor and uses them to tune the mixture. So with a problem with the sensor, closed loop operation is impossible.
All Civics lack low-end power. Don't expect proper operation with the CEL on and a code set though. After clearing that up, you should also check the spark timing.
cdblack1990
18
Jan 22, 2008 04:39 PM
psychocarne
16
May 24, 2007 01:31 PM
sam@missionspeed
Oct 20, 2005 10:25 AM
Shandles
Oct 7, 2005 08:53 AM
big
Aug 9, 2005 03:11 PM
